ZLauncher ZScript allows you to store your favorite ZScripts in easily accessible
iconized list which may contain up to 100 ZScripts.
ZLauncher features…
Easy to configure and use. Clicking on an icon to assign or launch a ZScript.
Icons may be added, removed or modified at any time.
Utilizes the full width of the ZScript window.
Adjustable icon size.
After loading this ZScript in ZBrush, press the ZLauncher icon to learn about its functionality.
Click here to download the ZLauncherRevA ZScript
The zip file contains two files that should be placed within your ZScript folder.
Note: The ZLauncherRevA.zsc <font color=#ffa000>should not</font> be renamed. Renaming this file will
not allow the ZScript to function properly.
AUTOMATIC LOADING OF ZLAUNCHER ZSCRIPT
The ZLauncher is most effective when it is used as the default startup ZScript.
In order for the ZLauncher to be used as your default startup ZScript, you need to
rename the included “AutoZLauncherRevA.txt” file to “DefaultZScript.txt”. If this
step executed properly, ZLauncher will automatically be loaded whenever ZBrush
is launched.
Have fun ZLaunching
-Pixolator
About startup ZScripts: There are several more variations of DefaultZScript.txt which
have been created and posted by ZBC members (the most recent ZScript posted by cameyo).
These ZScripts offer alternative startup ZScripts with variety of features which you may want
to explore in your search for the perfect-fit startup script
