Ok, I am running into a bit of problem creating an icon. I know it looks straight forward enough when reading it, but consider who you are dealing with here. I run the ZScript and do a grab. Resize the texture and export with the psd extension. When I alt click on the ZLauncher icon to add it, the script loads, but no icon. Is there something I am missing? Do we export to the same file the script is loaded into. If so, that is done. Any help would be appreciated. Thanks!
Hi D
The Icon you make must have the same name as the script, except it will have the PSD extension of course.
The Icon must be in the Same directory of the Zscript that it is for.
I think possiblyperhapsmaybe that your problem lies in #2
To make the whole thing easier use my Icon Widget
here
Hope that helps
Thanks, that clears it up!
Digits: Thanks for posting your IconWidget ZScript
Those who are interested in ZScripting may download the <font color=#FFa000>Z</font><font color=#FFFFFF>Launcher</font> source code (.txt) by clicking in here .
Notes about the <font color=#FFa000>Z</font><font color=#FFFFFF>Launcher</font> source code:
1. The icons that are shown in the ZLauncher buttons are automatically extracted from each of the assigned ZScripts. This is a new ZScript feature that allows you to specify any of ZBrush’s native formats (such as ZBR documents, ZTL tools…) as an image and ZBrush will automatically extract the embedded icon.
Example…
[Image,”A_Tool.ztl”] will display the embedded icon of the “A_Tooll.ztl” tool. This method can also be used for IButton command (which is what ZLauncher is using ).
2. The code includes a self-contained routine which asks user to confirm an action. This routine sets the ‘doConfirmedAction’ to 1 if user chooses to execute the action or to 0 (zero) if user chooses to cancel the action. This routine can be used ‘as-is’ in your own ZScripts when similar functionality is required.
Hope this helps
-Pixolator
P.S I am planning to write (when time permits) a new ZScript to have similar functionality to ZLauncher but with the added capability to include All of ZBrush file types (tools,lights,materials…). Meanwhile, the ZList ZScript offers similar functionality and it is available in here
This is great. I would love it, if…
But why does it look so funny on my 1.55b screen and not at all as you show?
And what means the “b” behind 1.55? Beta?
(I have the purchased version)
Thanks for your help
Guitta
gabe: Here is why…
starting from the left icon…
Icon number 1 leads to a ZScript in ZSC format which was created for an iconless ZScript.
Icon number 2 Leads to an iconless ZScript in TXT format.
Icon number 3 Leads to TextureMaster revision E or earlier. You need to use the newer version of TextureMaster (revision F) which is already included with 1.55b.
Icon number 4 is the correct ZLauncherRevA icon.
You’ll find more information about creating icons in the previous posts within this thread.
The ‘b’ simply means that it is a newer version than 1.55 or 1.55a (including all 1.55R?).
Hope this helps
-Pixolator
Hello
I translate the files of ZB into French, and during the use in ZB I do not have icone, some is the format used! (zsc or txt). Do you Have a solution?
By
Vincent (French translator)
PS: i work on Mac Os9.1 and G3 BB
Ok…!!
With ZScript : Digit_Widgets_Icon.txt . Thank and By
Vincent
Thanks for your replies. I understand now.
Guitta
I just said that I understand, but in my 1.55b is only the textureMaster Rev E included, not F. Where can I find it?
Guitta
I have already been at the Poxologic site, but if I click the Texture Master…F link, it goes to the 1.55 demo download page.
Well, I have just one observation about the Zlauncher. I spent about 3 hours loading it up with my favorite original, materials, textures, and tools. Alas when I went to use it, I noted that although all the thumbnails are there, some of the materials, and textures do not load. Any ideas as to why this might be?
Thanks.
Oh thanks you’re right! Duh, ignore this post I put it in the wrong thread…
:o
Do you mean the ZList http://www.pixolator.com/zbc-bin/ultimatebb.cgi?ubb=get_topic&f=1&t=004002
rather than the ZLauncher utility Northstar?
if so then I have the same problem.
gebe, the copy of TextureMaster that downloads with version 1.55b IS revision F. It is located in ZScripts\Utilities\TextureMaster.
There are a few possibilities:
- You haven’t yet upgraded to version 1.55b (which according to my database, you’re entitled to do).
- You are looking in an old ZScripts folder
- After installing version 1.55b you copied your ZScripts folder wholesale from your older version, overwriting Revision F in the process. If this is the case, you’ll need to open the downloaded archive again and re-extract the TextureMaster folder.
Since TextureMaster is now included in the downloads of both the commercial and demo versions of ZBrush, it no longer made sense to have it available for download separately. This is why the ZScript Library points to the demo download.
Thank Aurick. I found out why I could not find it. I have done a copy/past of my “old Zscripts” from 1.51 to the 1.55 folder. I have now reinstalled the right files and it works. Thanks again.
Now another question: I have created lots of thumbs and have a nice ZLauncher sitting on my screen:).
But when I click one of these scripts to follow it, the ZLauncher disapears. Is there a way to get it back without shoting down Zbrush and restart it?
Would really be nice.
Initialize ZBrush doesn’ bring it back.
Guitta
Found (thanks Digits) the response to my new question about the call back ZLauncher:)
Hey Pixolator,
First off love the ZLauncher Script! Makes life a whole lot easier! May I suggest an idea for ver 2, that I think would make it an all-around-as-close-to-perfect-as-one-could-possibly-get-script?
Can you add the ability to add your own short-cuts say, to resize the document, like Southern’s Default ZScript Rev 1.0 has? And the ability to section off blocks of icons/buttons? That would be cool!
I thought I’d share the icons I’ve for ZLauncher that don’t have their own icons.
ColorQuick by Aurick
ColorQuick.psd
AlphaManager - Beta by Southern
ZBrushloader.psd
and
Brush Stocker 1.12 by Kaz-g
BrushStocker1_12.psd
Jason
About ZLauncher
Is this script up-to-date or is there a better—no, not better— lets say more complete Zscript made since then??
Also’ It seem like it was scripted for version 1.55b can I still use it with version 2 or is there an integrated (similar) Zscript inside version2??
What about ZList script… is it also up-to-date for ZB2??
As a mather of fact, for a newb like me who is also new to these forums, it is not that obvious to witch Zscipt is old and witch one is new or at least still very paractical since there are no subtitute in ZB2 as we speak (post) Maybe someone should post THE List of all the Zscript out there for use with ZB2 and / or ZB1.55b. and knowing witch ones are no longuer usefull for ZB2 since it was integrated into the said version or a similar Zscript. Dont you think??
zlauncher works with z2 for sure cuz I use it.
check the dates of the scripts first post…that will give you a pretty good idea of how old it is. Also check the last couple posts…if they don’t work in z2, you’ll find that people were asking about it etc.
If I get a chance this week I will go thru all my old ones and post which ones still work and which don’t.
