Cape Tip using Dynamics and Anchors Brush.
making a strap with Dynamics.
Applying a polygroup to a flat surface using PolygroupIt.
Materials that have Special modifiers.
Making stitches with nanomesh and the default IMM brush in lightbox.
Stitching with IMM curves. Tweaking the default IMM brush inside lightbox.
ZBrush 2024’s NoiseMaker and applying them several times to get a gore surface.
Partial rendering with Redshift.
Creating a cracking effect using knive curves.
ZBrush 2024.0.1 Anchors classic and Anchor difference.
Thank you for all the tips and tricks!
using the default VDM brush and getting some fluffy things.
Creating some Skeleton Frame looking shape with morphtarget, create diff and dynamic subdiv.
2024 Anchor Brush + Focal Shift.
using Anchor brush to position a hose.
Dynamics + Morph Target will prevent the mesh from over stretching.
ConstZ vs Closest Z, best picker setting for hair curves.
creating AO maps.
Great format and content
using a Cube to add keying for hairs.
