ZStartup Master! unofficial - Information, Installation
ZStartup Master
[CLICK HERE TO GET CURRENT VERSION]
(Current Version 3.1 Updated 6/6/2016)
by: Joseph Drust
ZStartup Master is a unofficial plugin that will store settings to auto load on ZBrush Launch. If you ever wanted to have ZBrush launch with a specific Matcap selected, specific Tool selected, or a specific Brush this plugin is for you!
This plugin is unofficial.
Main features
- Creates a DefaultZScript Startup file with specific settings that will auto load on ZBrush launch
- Allows for items such as Specific Matcap, Brush, and Tools to auto load at launch.
Usage/Tutorial
Installation
**** Make sure you have updated to âZBrush 4R7 P3â or later! *****
ZBrush 4R7 32bit:
UnZip the attached ZStartupMaster_v1.1_x32.ZIP file to your \Pixologic\ZBrush 4R7\ZStartup\ZPlugs\ folder.
Restart ZBrush.
ZStartup Master will be located under the Zplugin tab.
ZBrush 4R7 64bit:
UnZip the attached ZStartupMaster_v1.1_x64.ZIP file to your \Pixologic\ZBrush 4R7\ZStartup\ZPlugs64\ folder.
Restart ZBrush.
Change Log
v1.1: Initial Public Release
Notes
I usually end up doing a few of the same things every time I launch ZBrush so I decided to automate this process. The plugin has not been tested extensively with custom UIâs so use at your own risk. If something is not working correctly after you âInstall Custom Startupâ just click âUninstall Startupâ and it will revert the changes. If you find bugs just post them in this thread and Iâll try to fix them
Trying out the Youtube usage tutorial on this one; hopefully it helps in figuring out the usage. Special thanks to marcus_civis for putting up with my relentless questions
-Joseph
[CLICK HERE TO GET CURRENT VERSION]ZStartupMaster_v1.1_x32.zip (48 KB)ZStartupMaster_v1.1_x64.zip (48 KB)
small_orange_diamond
) pressing âALTâ will force the error messages to appear.
) This is making me believe that the plugin is conflicting with another plugin. Comparing your answers with the ones Wyattfox and valencia1992 will hopefully help me in reaching a resolution (if this version is still causing the error.)
