Hi.
Using ZScript I’ve been trying to manipulate ZSphere properties i.e. x, y, z positions using ZSphereGet and ZSphereSet commands etc. ZSphereGet seems to work fine, but ZSphere set, when applied to certain things like x, y, z positions seems to be misbehaving, it’s not working properly and is misplacing the ZSpheres even though the logic appears to be fine. Any suggestions? Might I be doing something wrong or is there a bug with the command or what?
To be a bit specific:
The x position for example. It can only be set between the bounds of a value of -16 and +16 for x, Ive tested it, but if you try setting it to say, 100, it will be set to the max bound of 16
Responses will be appreciated.
