Zscript keep repeating an if statement
Hey I’m new to Zscript I had a class of JavaScript and there you could check every frame if the if statement was true, now I was wondering if you can do that here. I’m trying to make a size slider that goes from 512 to 1024 to 2048 to 4096.
[ISlider, Size, 512, SizeSliderVal, 512, 4096,]
[If, SizeSliderVal>512,
	[VarSet, SizeSliderVal, SizeSliderVal*2]
I’m afraid you can’t set the slider resolution on the fly. The best you can do is something like this:
[ISlider,“Size”,512,512,512,4096
,“Popup info Text”,
[If,([IGet,0]>1024)&&([IGet,0]<2048),
[If,([IGet,0]>1536),
[ISet,0,2048]
[ISet,0,1024]
[If,([IGet,0]>2048)&&([IGet,0]<4096),
[If,([IGet,0]>3072),
[ISet,0,4096]
[ISet,0,2048]
,0,1]
Note that [IGet,0] in the above code is a short way of writing “get the current value of this interface item”.
Thanks man you’re a life saver I will put it in once I continue my script.
