Hi guys,
ever since I switched from windows XP I've had the annoying problem of not being able to see any zplugins in the plugin list.
At work I had windows Vista 32bit, and had the same problem I have now.. the plugins didn't show up. But since it worked perfectly on my home PC, which used XP, it wasn't an issue.
To avoid the problem I skipped Vista and purchased Windows 7 64bit edition during a home PC upgrade, only to discover that now I have that same problem and no longer have an XP PC to use the plugins on.. which you can imagine is rather annoying :)
I noticed there are a few similar topics, but none have answers to my problem, since they mostly used older versions of Zbrush. I use ZBrush 3.5 R3, and like to think by now I know how to install Zplugins properly ;)
edit I’ve put the plugins in the ZStartup/Zplugs folder ánd the ZData/Zplugs folder… same result. Only Quicksketch is listed in the program menu.
I added a relevant screenshot anyway. Hopefully I missed a topic or perhaps the pixologic wizzkids are already working on it
Regards.
[[attach=192075]plugins.jpg[/attach]]
