What is [COLOR=Yellow]ZMATS+?[/COLOR]
ZMATS+ is an upgrade to the original ZMATS, a handy manager for ZBrush Materials and light setups.
WARNING TO CURRENT ZMATS USERS:
BE SURE TO USE THE ZMATSPLUSUPDATE VERSION!!!
Two alternate ZIP files are made available for upload here:
For people already using ZMATS, you should download ZMatsPlusUpdate.zip.
First time ZMATS+users will want to download ZMatsPlus.zip which includes ALL the files and subdirectories needed for a completely new install.
NOTE: When I posted the original ZMATS, some people mistakenly thought it included a library of materials. Nope. The scripts for ZMATS and ZMATS+ simply provide users with a tool for MANAGING materials. You have to create or load your own library. There are several existing libraries that you can download and convert for use in ZMATS+. Read about these options in the original ZMATS thread >> HERE << . Be sure to checkout the handy filename conversion utility generously posted by Marcus_Civis in that same thread.
ORIGINAL [COLOR=Yellow]ZMATS FUNCTIONALITY[/COLOR]
Multiple Bank Storage: There are five Material BANK buttons (A,B,C,D and E) and one Light BANK button, each bank can store four hundred materials or lights. Total material storage for ZMATS+ is 2,000 different materials and 400 lights.
Each material being stored is applied to a sphere. (The spheres are branded with a depressed “Z” to better display some characteristics of the stored material.)
Many times the character of the material depends on lights and color. Besides the material, ZMATS+ also stores the lighting setup and the RGB color in use at the time the material was stored. You can separately reload the lights and/or color by clicking on the mini-icons in the lower left and right corners of the material’s window.
An Undo button lets you recover a previous material if you accidently load a new material before saving the old. The Undo operation is one level only.
The Help button provides a complete explanation of ZMATS+ button functionality.
ADDED [COLOR=Yellow]ZMATS+ FUNCTIONALITY[/COLOR]
A new LightBank button has been added. This bank can store upto four hundred lighting setups. Each setup is displayed as a Best Render shining on a standard sphere which displays a good approximation of the lights’ effects.
The new Find button brings up a window displaying a block of forty materials at a time. Ten page blocks of materials can be veiwed sequentially using the arrow keys. You can also jump directly to any one of the ten blocks by pressing one of the ten block buttons. At anytime you may click on a specific material thumbnail, which immediately loads that material. The five slot windows are updated so that the loaded material is displayed in the center slot. If you wish, you click the light icon or color icon of the material you just loaded.
INSTALLING [COLOR=Yellow]ZMATS+[/COLOR]
Current ZMATS Users:
Installing ZmatsPlusUpdate.zip is simple. Just unzip the contents into the ZPlugs directory. Answer YES TO ALL and the necessary files, new and updated, will be installed leaving your existing materials intact. A new Lights subdirectory will also be added along with the necessary light files.
If you are worried about overwriting existing materials, you should first make a backup copy of the Bank directories just to be safe.
New ZMATS+ Users:
Installing ZmatsPlus.zip is simple. Just unzip the contents into the ZPlugs directory. All the necessary files will be placed in a ZMATS subdirectory except for the ZmatsLauncher.zsc script which must be in the ZStartup\ZPlugs directory.
When you restart ZBrush2, look for a ZMats button in the Zplugin menu under PSNAP group.
This ZMats button can be Control-dragged to one of the shelves on your interface and made a permanent part of your startup UICustom.cfg file by pressing Control+Shift+I. Now, anytime you need to load or save a material or light setup, just press the ZMats button.
[COLOR=Yellow]ZMATS FOLDER AND SUBFOLDER CONTENTS[/COLOR]
The installed version of ZMATS+ should look like this:
ZStartup\Zplugs subdirectory will contain:
ZmatsLauncher.zsc
Zmats subdirectory
ZStartup\Zplugs\Zmats subdirectory will contain:
Zmats.zsc
Zmats.psd
ZmatsPlusThumb.psd
matexample.psd
undo.ZMT
UnDoA.ZMT
UnDoB.ZMT
tempMats.ZMT
templights.ZLI
Mtemp.ZMT
LightMat.ZMT
background.ZMT
undo.zli
UnDoA.ZLI
UnDoB.ZLI
ztool.ZLI
bankA subdirectory
bankB subdirectory
bankC subdirectory
bankD subdirectory
bankE subdirectory
Lights subdirectory
ZStartup\Zplugs\Zmats\bankA subdirectory will contain:
BankA folder.txt
ZStartup\Zplugs\Zmats\bankB subdirectory will contain:
BankB folder.txt
ZStartup\Zplugs\Zmats\bankC subdirectory will contain:
BankC folder.txt
ZStartup\Zplugs\Zmats\bankD subdirectory will contain:
BankD folder.txt
ZStartup\Zplugs\Zmats\bankE subdirectory will contain:
BankE folder.txt
ZStartup\Zplugs\Zmats\Lights subdirectory will contain:
LightBank folder.txt
small_orange_diamond
