New user question. How do you set the inner and outer diameter of a 3d ring in ZBrushCore?
Thanks, Alan
Thanks, Alan
Hello @ara2060,
Outer diameter is simply a function of the mesh scale. You can scale the bounding box of the ring with Gizmo/Transpose or the Tool> Deformation> Size slider.
The inner radius can be adjusted in the Tool> Initialize menu prior to making it a poly mesh 3d object.
So the topic sums up my problem. I add a 3d ring but I can’t find out where to change the inner and outer diameters of the “donut”.
Thanks, Alan
Excellent! That’s what I needed. Thanks much!!
