Has anyone had issues with Zbrush after updating to OS 10.15.3? My palette buttons and some sliders are mismatched to the curser selection now. I have to aim above the buttons to select the functions. I can’t grab the History slider button either.
Thank you for the suggestion. Unfortunately, this did not correct the problem…it locked up even more. Had to Restore to standard UI, which brought me back to my original problem.
Then this is something that the developers should be made aware of. I would suggest you submit a ticket to support. They would be the most qualified to iron out this issue for you.
Yes, thank you. I did. Hopefully I will hear back from them soon.
