ZBrush 4R7, KeyShot for ZBrush + Bridge Introduction
Thursday, Feb 5th at 10AM PST, we’ll be giving an intro to KeyShot for ZBrush + Bridge. We’ll show the installation and Concept Artist Nick Hiatt will take you through the process. Here’s the description.
Guest presenter and film industry veteran, Nick Hiatt, gives you an introduction to KeyShot for ZBrush and the ZBrush to KeyShot Bridge, taking you through the process from setup and paint in ZBrush to transfer and lighting in KeyShot. This is expected to fill up quickly so grab your spot fast. Topics:
  • Download, installation, and licensing
  • Mesh setup in ZBrush
  • The ZBrush to KeyShot Bridge
  • Light and material setup in KeyShot
  • Model updates from ZBrush to KeyShot
  • Tips, tricks, and techniques
  • Q&A
Can we post questions about Keyshot here, or would it be better to post them elsewhere?
Thank you. :slight_smile:
One minor thing I’ll mention, is that it the webinar the other day it was stated that that the Zbrush render settings don’t react with Keyshot in any way. That’s true for the most part, but an exception is “Smooth Normals” in the ZBrush Render Properties menu.
This will send the Zbrush render object to Keyshot with smoothed normals, which is useful for removing the appearance of poly facets from a low poly object without increasing geometry.
Thank you! :+1:
I had no idea what was causing facets to show, in ZB and/or KS.
This is a useful tip. :slight_smile:
There is the KeyShot forum where you can ask questions about KeyShot. Signin
The ZBrush board on there is:
https://www.keyshot.com/forum/index.php/board,59.0.html
The board to share artwork is:
https://www.keyshot.com/forum/index.php/board,5.0.html
Thank you for those links, Josh. :slight_smile:
thank you for the advice with the “smooth normals” option
:+1:small_orange_diamond:+1:small_orange_diamond:+1:
