ZBrush 2025 Spring Release
ZBC_Post-Apr2025_Release-800x1200px
ZBRUSH 2025.2.2 DESKTOP UPDATE
  • Fixed an issue where the focus of the Quickmenu was not on the brush size.
  • Fixed a stability issue with Array Mesh and Redshift rendering.
  • Fixed an issue with Redshift SSS Material rendering artifacts.
  • Fixed an issue where flipping the display normals caused a broken mesh.
  • Fixed an issue where ZBrush to Photoshop functionality was not working.
  • Fixed a stability issue when enabling KeyShot rendering without the software being installed.
  • General stability improvements.
ZBRUSH 2025.2.1 DESKTOP UPDATE
There has been an update to ZBrush desktop. This will be version 2025.2.1. The following have been fixed in this update.
  • Fixed an issue where some items in the ZPlugin: Misc Utilities were missing
  • Fixed an issue with NanoMesh Brush not working with “M” key’s Tool menu
  • Fixed a stability issue with saving curve profiles as ZCV-files
WHATS NEW
ZBrush has received an update for both desktop and iPad. The ZBrush version number for desktop will be ZBrush 2025.2.0 and the iPad update will be ZBrush 2025.3.0.
We’re keeping the ball rolling with more additions to ZBrush. Discover what has been added to ZBrush below.
ZBRUSH 2025.2.0 DESKTOP ADDITIONS
The upcoming Spring release will feature several new updates for ZBrush for desktop which include the following.
ZModeler
There are three new additions to ZModeler, the most significant being our ZModeler Presets.
  1. ZModeler Presets
This feature will enable you to store your favored ZModeler options without needing to open all the settings for ZModeler. Each of your polygon face, edge, and points actions can have their own set of Presets.
Screenshot 2025-04-01 at 5.19.08 PM
  1. Edgeloop Snapping.
This feature enables you to snap an insert edge loop to the center, quarter, or a user-defined range of 2 to 10 snaps within the edge loop receiving the inserted edge.
  1. Polygon Selection Mode
This feature utilizes the temporary Polygroup capability of ZModeler. Rather than applying it to one polygon at a time, you can now use any ZModeler Polygon Target to implement the temporary Polygroup, such as Polyloop. Consider this like selecting faces to which you can then apply another polygon action.
Redshift Attributes Added & New Redshift Materials
  1. New Redshift Material Attributes Added
The Redshift materials have undergone another update, bringing the ZBrush Redshift materials in line with other applications that support Redshift. All the attributes found in standard Redshift materials in other applications are now available in ZBrush, opening possibilities for creating more unique Redshift materials within ZBrush.
  1. 18+ Additional Redshift Materials Added
Now that the ZBrush Redshift materials have been updated, this opened up us to create more materials to render with Redshift in ZBrush. We’ve added several new materials, such as Dimond, GlassHollow, Jade, Emerald, Pearl, MetalRough, RedWine, Ruby, Sapphire and so many more.
Redshift Materials
Pro Projects
Pro Projects have continued to expand in this release, with more to come. These are exciting collaborations with prominent artists within their particular fields and give ZBrush users an opportunity to see how professional artists complete their work. Pro Projects include the actual assets from the artists for you to dive into and discover how did the artist make that piece.
Continuing the journey of teaming up with our amazing community, we’re proud to announce two more Pro Projects.
This release will include a Pro Project from Pablo Munoz Gomez and Henry Chervenka.
Pablo Munoz Gomez Project Assests
  • A completed sculpt that showcases how you can use ZBrush to create 2D final images.
  • 5 new brushes that can be found in Lightbox>Pro Projects on desktop and in the Brush picker on iPad, which 1 brush located in Insert Mesh category and the other 4 located in the Sculptural category.
  • 4 new textures located in Lightbox/Textures/Pro Projects folder on desktop and in the Texture picker on iPad.
  • His project also contains a material that’s perfect for that 2D toon shaded look. Plop your model in his project, click BPR to render and see what your work looks like in Pablo’s 2D inspired project.
Pablo
Image Courtesy of Pablo Munoz Gomez
Henry Chervenka Project Assests
  • A final vehicle called ZRide that showcases how ZModeler can be used to create a complex design and still maintain clean topology. Do yourself a favor, open up the project and take a look a close look at the tires. Henry’s left us some fun information for us to discover.
  • A fantastic new IMM brush that contains all of the switches Henry created for his ZRide master piece.
Henry_Chervenka_01
Image Courtesy of Henry Chervenka
ZBRUSH 2025.3.0 IPAD ADDITIONS
The upcoming Spring release will feature several new updates for ZBrush for iPad which include the following.
  • Pro Project Additions
The iPad version also comes with the same two new Pro Projects from Pablo Munoz Gomez and Henry Chervenka that you’ll find in our 2025.2.0 desktop version.
The free version of ZBrush for iPad will not encompass the Pro Project brushes or textures. Only the models will be provided with the free version of ZBrush for iPad.
  • Brush Updates
  • Anchor brush has been updated to include the new Bend mode.
  • NEW Quick Polygroup brush is now shipped with the iPad version, allowing for a one click solution to create Polygroups based on topology.
  • NanoMesh
Provides you with an instancing system to edit and transform any mesh after it’s drawn to the surface, while keeping your polygon count low.
  • UV Master
This plugin has made its way to the iPad as well. With our unique control painting option, UV Master lets you layout UVs in an artistic way to meet technical pipeline needs.
Screenshot 2025-04-01 at 6.07.02 PM
  • UV Unwrap From Creased Edges
Use creased edges to define the exact edge that you’d like your UV seam to follow.
  • VDM From Mesh and To Mesh Added
You can now make your own VDM 3D alphas with the To Mesh and From Mesh options on iPad. These brushes help you create alphas that respect undercutting when sculpting. Check out our Chisel brush collection to see what’s possible with 3D VDM alphas.
  • New Modifier Wheel Sizes
As you requested, we’ve added to new modifier wheels size, 2XL and 3XL.
Wheel Sizes
Just use the Gizmo3D to swap any mesh from an Insert Mesh brush by clicking the mesh in the IMM Viewer.
  • Gizmo IMM Replacement
  • Store Custom QuickMenu in your floating Tray.
We always want you to have the features you use most right at your fingertips. With the custom QuickMenu, you can easily control the settings you want to keep handy. This version lets you add your Custom QuickMenus to a floating Tray.
Screenshot 2025-04-01 at 5.41.21 PM
Custom QuickMenu in Floating Tray
The All New ZModeler ZBrush for iPad Additions
  1. New Ui Design
In our ongoing effort to incorporate desktop features into the ZBrush iPad version, we have explored the feasibility of adapting ZModeler for smaller devices, including the iPad mini. Consequently, we have developed a new UI for ZModeler on the iPad, and introduced new workflows with the UI.
ZModeler works best with a mouse/pen hover state, so we suggest using an iPad with hover state capability or a mouse with your iPad for the best experience. But don’t worry, you can still use ZModeler on non-hover state iPads.
For example
  • You can select Polygon Face, Edge, and Vertex components without having to hover.
  • Feel free to place the ZModeler UI wherever works best for you.
  • Use long press to recall your stored Presets
  • For easy access to the temporary Polygroup, just click the new icon in the ZModeler Ui.
  • You can find the most used ZModeler options like Dynamic Subdivisions, Creasing options, and ZModeler modifiers right alongside the rest of the ZModeler UI.
Screenshot 2025-04-01 at 5.49.47 PM
Fresh New ZModeler Ui, built for iPad
Screenshot 2025-04-01 at 5.44.19 PM
Floating ZModeler Menu with Presets Selected
Screenshot 2025-04-01 at 5.45.35 PM
ZModeler Long Press to Presets
  1. ZModeler Presets
Screenshot 2025-04-01 at 5.46.50 PM
Screenshot 2025-04-01 at 5.47.40 PM
Screenshot 2025-04-01 at 5.48.44 PM
AVAILABILITY
ZBrush 2025.2.0 Desktop and ZBrush 2025.3.0 iPad is part of your subscription(those who have a monthly or annual license). Simply use the Maxon App to upgrade ZBrush to 2025.2.0 for desktop and update your iPad ZBrush 2025.3.0 version through the Apple App Store.
  • Maxon One subscribers will be able to use Redshift GPU or CPU in ZBrush and will include a ZBrush desktop and iPad activation.
  • ZBrush Desktop subscribers will be able to use Redshift CPU in ZBrush. ZBrush desktop subscribers also receive a license to ZBrush for iPad with their subscription.
  • ZBrush iPad Apple App subscribers will get the iPad update. If you want access to the ZBrush 2025.2.0 desktop version and Redshift, you’ll need to upgrade to a ZBrush or Maxon One subscription.
Purchasing (New Users)
ZBrush 2025.2.0 desktop may be purchased from our online store for immediate download. Annual and monthly subscriptions are available. With a ZBrush desktop subscription, you’ll also get a license for ZBrush iPad and CPU Redshift version.
Purchase the ZBrush 2025.3.0 iPad-only subscription directly from the Apple App Store on your iPad. Both annual and monthly subscriptions are available, as well as a free version of ZBrush for iPad.
Issues?
If you have any issues with upgrading or with the new features, please start a Support Conversation . Please note that account and login issues can only be handled via a Support conversation.
Can we just get a Quad Draw Retopo function inside of Zbrush? The community has wanted this for years, why do you continually ignore the most sought after function? Even blender has Maya’s quad draw function for free with a free extension, its nonsense that we’re in 2025 and you still haven’t implemented this.
Also fix the knife cut tool from crashing the app, its absurd that this happens so much.
Have you tried the ZModeler retopo feature? This is something that is similar to Quad draw. We are also looking at what retopo could be implementing. We are also working on some other feature requested features that still need some more time to develop.
Can you share a model that crashes with Knife brush. We’ve done many changes in the last few builds to stabilize any known crash issues but if you can provide something that can repeat the crash 100% of the time that will help us look into that portion of the code and give us a mesh to use as a test to see if we fixed the issue.
Anything in greater detail would be a great help.
@PixoPaul Please, please, please Paul, can you give us an option to disable model rotation on the empty canvas? It’s one of those things that seems glaringly obvious that it’s a big issue with an easy fix. Even though I’ve been using ZB for over 20 years, it’s something I will never get used to.
You being a fellow Right-Click navigation champion I’m surprised it’s not top of your list too. :grin:
Internet (and a years old post on here too) is awash with many pleas to fix this issue.
As for manual retopo, Zmodeler can be quite clunky. I actually still use old-school ZSphere retopo instead. ZM retopo is very fiddly and can be frustrating when snapping to an underlying surface. For me, it’s just less hassle to use Zsphere topo and avoid the headaches on more complicated retopo jobs.
I would love to see a more reliable version of ZM retopo, with some expanded tools to bring it in line with Topogun, Maya Quad-draw, or Blender Polyquilt addon.
Any news on what’s happening with desktop? You hinted at some stuff on the last release stream. We hardcore desktop loyalists are feeling more and more like we have been a little bit abandoned for the ipad version.
@DannyMcGrath Thanks for taking the time to send this post.
Just to be clear, you want to keep the model in one location while you are sculpting, while you sculpt, correct? If so, this is possible already with the Lock Camera mode in the Draw Palette. Have you tried that yet?
Yes, I have a new retopo on the list to look into for us. It’s something we just had some discussions on but I can’t share much at this time.
As for the desktop. The team is working on some new features, some of them are going to take a little more time and are a bit larger projects. We have a bunch of items we have in store for the desktop, it’s just taking some time for us.
The team has several ideas, we just need to map them out in a schedule.
Let me know if there is anything else.
@PixoPaul Hi Paul, I didn’t realise it was you answering the suggestion emails on the Maxon site. :smile:
Nice try, :wink: but the lock camera function isn’t really a solution, imo. The canvas is being constantly rotated and scaled in and out while sculpting (especially if you’re sculpting a silhouette in the round) so having to keep locking and unlocking the camera is equally as frustrating in its own way. The way I see it is if I have ‘right click navigation’ set as my chosen method, then the left click rotate should be disabled completely.
If there is already a function to lock the camera, then couldn’t something like this be an automated process running in the background which essentially disables the canvas rotation if a sculpt stroke is detected that doesn’t start on a vertex?
Great news on the desktop and potential new retopo tools. Thanks for letting us know. Really excited to see what the team comes up with. :+1:
@DannyMcGrath This is something we have to look into because as you know, which you are running into, both navigation systems are always on, so we would need to investigate the idea of adding an option to turn only one on. There are a lot of other things we need to consider for this idea.
I’ll add it to the list of ideas to investigate.
All the best.
@PixoPaul Thanks Paul, that’s all I can ask. :+1: I realise that the canvas rotation is reliant on the cursor being over an active vert or not, so I’m sure it’s not just a simple matter (under the hood), but I honestly think that this would greatly improve the overall user experience navigating. Cheers.
