Zbrush 2021 update Keyshot Bridge bug
Hi all,
I have an issue with the KeyShot Bridge.
When I sending a model to KeyShot using the ZBrush to KeyShot Bridge I receive an error that says “Unable to Connect to External Renderer.”
I use Win 10 pro, 64 bit and followed these steps,
ZBrush | Digital Sculpting Software. Sculpt & Create
1. Disable your antivirus software. This includes Windows Defender. Failure to follow this step will often result in a corrupted installer that fails partway through installation.
8. If you have the ZBrush to KeyShot Bridge, run it and activate as well.
9. Enable your antivirus software again.
Problem in Win 10 Pro, 64 bit, - there is no button to turn off Microsoft Defender.
Compromise solution, if I open Keyshot manually before I send a model to Keyshot then everything works as expected, unfortunately the solution is not entirely correct.
Does anyone have a solution?
I thank you for your efforts,
Christian
