XYZ FONTS for ZBrush 3.1 Update
Hi Peoples,
here are my plugin set for ZBrush 3.1
Sorry but this time i just can present seven fonts.
So in ZBrush 3.1 must be a big bug.
What i mean is that: in three font i’m using the flatten function on the tool palette.
I make with an alpha and the “make 3D” function a 3D tool and than i make flatten at the ZAxis.
Exactly at this point ZBrush crashs down :evil: :-1:
are you guys having the same problem? try it out and let me know.
Try the alpha 09 set MDep 40 and MRes 100 and make 3D.
Now go to the Tool Palette/Deformation and make flatten on the Z axis.
I’m wondering whats happen.
Roland
[attach=65535]xyz-fonts.jpg[/attach]
So Peoples,
I removed this flatten steps on my last three fonts plugs. so they working
now.
I fixed also en texture map problem on the “Pristina” font. So, if you have installed this plug, then install it again.
OK, i changed again some function. I add new a flatten slider.
so that everything works without crashes.
more instructions here:
http://www.pixolator.com/zbc/showpost.php?p=360196&postcount=1
Roland
I’ve got same result!
