Good work you done very well , and i learn this forum and it is very good .
Is Pixols to 3D being updated for 4R7 (64 Bit) ?
Iād like to try it out with Keyshot for Zbrush.
I am testing the 64 bit and it works as a charm (thank to Marcus Civis!)
It is wonderful connected to KeyShot.
In the next days I will prepare some images.Meanwhile I will ask to Marcus to upload the 64 bit version.
Thank you Francesco. I am a fan of your work.
Doug
Iāve updated Pixols To 3D for ZBrush 4R7. Windows only at the moment, hopefully MacOSX later this week.
See original post:
http://www.zbrushcentral.com/showthread.php?172391-Default-Useful-small-ZScripts-and-Macros-for-ZBrush-4R4&p=979836&viewfull=1#post979836
OOOh! looks like I need to set aside some playtime later this week!
Thanks Marcus, for keeping Zbrush a āpaintersā program.
Doug
Thank you acmepixel!
marcus_civis
Iāve updated Pixols To 3D for ZBrush 4R7. Windows only at the moment, hopefully MacOSX later this week.See original post:
http://www.zbrushcentral.com/showthr...l=1#post979836
Any news on the 4R7 Macintosh version?
Oh goodness! Iām so sorry, it completely slipped my mind. Itās done, and here: http://www.zbrushcentral.com/showthread.php?172391-Useful-small-ZScripts-and-Macros-for-ZBrush-4R6&p=979836&viewfull=1#post979836
Thanks for the cool plugin!
Many thanks Marcus!
Hey CREEDFX,
I noticed you have PMs turned off so Iām posting my question here instead.
I LOVE your Boolean Subtract zscript! I agree with you that using subtraction booleans in zbrush has too many steps involved.
My only critique on your zscript would be to have it automatically set the SUB Icon on the second subtool in the list, and also probably force the Add (default) icon on the top subtool as well.
Keep up the good work!
I really like it
Hope you can more and more development :))
Man thanks for the sharing hope we wille see some more Zscripts and Macros .
I am not a programer, just an artist. I see the script for the default material plugin . How do you install the thing. The text has to be converted to a ZSC file to be read by zbrush. Do you have the readable ZSC file foe this plugin to download.
You can load the text file using the Load button in the ZScript palette. ZBrush will then automatically create the ZSC file. For plugins you can then install the ZSC in the ZBrush 4R7\ZStartup\ZPlugs64 folder (or ZBrush 4R7\ZStartup\ZPlugs for 32bit). The plugin will then load when ZBrush starts.
You might be interested in this video of changing the default material:
https://youtu.be/7ukY3Xā9uQ?list=PLMjnnUF3eJFcO0e6lM2xSQ4xiexTvY_fk
And hereās Josephās plugin that allows you to change various startup options:
Here is a first pass on a collection of small macros and tools that Iāve been working on
Just click on the āDownload - E Tools.zsc v1.2ā link at the top of the webpage in the above link and then simply extract all of the contents from the .zip into your Zstartup/Zplugs or Zstartup/Zplugs64 folder. Then when you run Zbrush you will see a āE Toolsā panel under Zplugin, where these scripts reside.
The above link also has a short description of each command inside of E Tools.
This grouping of āE Toolsā replaces all other previous scripts (āZplugin > Eā) that anyone may still be using by me.
Big thanks goes to Nick Miller (Nyx702) and Marcus Burgess (marcus_civis) who helped me out a lot on many of these scripts!
Please test it out and let me know if you have any suggestions or issues! I am an extreme novice zscripter so be gentle
Wrote a MatCapToggle macro, adapted from Marcusās BrushToggle. Basically just switches between two materials, saves them between sessions, etc. Considered allowing more materials, but decided that would be superfluous.
MatCapToggle.txt (2.11 KB)
Thank you so much for this script my dear Marcusā¦I am sure that many skilled old school Zbrushers will show
us another side of the infinite capability of Zbrushā¦
Of course everyone is invited to suggest new things or to improve the script!
Long life to the Pixol!
Redbubble,Spreadshirt uk,teefury coupon,t shirt hell,threadless us,Teespring coupon,Teepublic coupon,80stees coupon codes
GoodMorning Everyone!
I have a question:
Is it possible to make a script or something that makes all PolyGroups in an object have a diferent material?
I need this for KeyShot renderingā¦
Also, Marcus, do you know if thereās any plan to allow us to have more than 1024 PolyGroups?
I need a LOT more, like preferable no limitā¦
Mealea
