***Instructions - simply extract all of the contents from each .zip into your Zstartup/Zplugs folder and then in zbrush under Zplugin you will see a “E” panel – where each of these plug-ins reside. ***
These are just a few very, very simple work flow scripts that I find very useful and others just for fun. I would reccomend using these as hotkeys if you like them. Just throw any of these into your ZStartup/Zplugs folder
<b> 1. PivotLocal_center. - </b>This script automates setting a local pivot of your model and then maximizes your model to the view port.
<b> 2. PivotClear_center - </b>this script automates un hiding all parts of your mesh and then clears its pivot and then maximizes the model in the view port.
<b>
3. mouse average 3 -</b> this script basically just changes your mouse average to 3.
<b> 4. mudbox - </b>this script copies mudbox's lighting and material and color as close as I could. (I used to use zmats to save them, but I hate how the script panel at the bottom keeps popping up while working. And yeah you can manually move it back down but that is annoying.)
All of these scripts are intended to be assigned to hotkeys, they are pretty pointless to use any other way in my opinion because the time it takes to go the plug-in panel and click on these buttons you could have just done what these do manually. So once again these are just quick workflow scripts to help speed up working in zbrush.
Big thanks to marcus for creating the zbrush hotkey editor which I would not have made these scripts otherwise and also thanks to TV Eyes for helping me out with one of these scripts.
