Scope in routines
I’ve got a routine that will reverse a string - or in this case correctly print “Hello Word!” forward from it’s reverse, as is my want.
Can I just check a couple of things, Marcus?
In order to return a parameter from a funct… I mean routine, you have to define it first and refer to it in the routine when returning.
Secondly what difference does the # make in loop?
Here’s my code:
// Define variable outside button scope
[VarDef, s, “!dlroW olleH”]
// Define routine here
[RoutineDef, reverse_string,
// Define an empty string
[VarSet, rev, “”]
// reverse the string
[VarSet,i,[StrLength,#s]-1]
[Loop,[StrLength,#s],
[VarSet,rev,[StrMerge,rev,[StrExtract,#s,i,i]]]
[VarDec,i]
// Set the routine paramater to the new string
[VarSet, s, rev]
// return parameter here
,s] // End of Routine
[IButton, “Reverse string”, “Reverse that string!”,
[Note, s] // forward
[RoutineCall, reverse_string, s]
[Note, s] // reversed
By declaring the ‘s’ variable globally you’re not using scope in your example (except with the ‘rev’ variable). You could remove the routine parameter and it would still work:
[VarSet, rev, “”]
[VarDec,i]
[VarSet, s, rev]
] // End of Routine
[RoutineCall, reverse_string]
If a variable is global - declared outside any code blocks - then it’s available anywhere. It’s not good practice to declare a global variable and then declare it again as a routine parameter. You’ll get errors sooner or later.
For a variable to be local you should not declare it outside the code block:
[VarDef, inStr, “!dlroW olleH”]
[VarSet, rev, “”]
[VarDec,i]
[VarSet, s, rev]
[Note, inStr] // forward
[RoutineCall, reverse_string,inStr]
[Note, inStr] // reversed
The hash # is just used to indicate a variable. It’s just coding style - it can make the code easier to read - and is ignored by ZBrush.
Thanks Marcus.
Local good. Jam good. Four legs good. Two legs bad. Got it :slight_smile:
I don’t suppose there’s a way in ZScript to determine if a variable is local or global??
[Note [x in global], 2]
Not directly, that I can think of, though simply using
[Note, [Var, myVariable]]
inside a button will give an error if the variable ‘myVariable’ isn’t available.
But for your own code you can adopt a code style that names global variables beginning with a ‘g’ and local with an ‘l’, such as gMyGlobalV and lMyLocalV.
Thanks, teach.
[VarDef, a, “a”] // global
[IButton, “Local & Global”, “Local & Global”,
[VarDef, b, “b”] // declared inside button, local
// [VarDef, c, “c”] // commented out - not declared at all
[Note, [Var, a]] // “a”
[Note, [Var, b]] // “b”
[Note, [Var, c]] // error
:+1: That’s it. :slight_smile:
Also:
[RoutineDef,ReturnC,
[VarSet,c,“Hello, I’m c!”]
,c]
//[Note, [Var, c]] // c is local so would give error
[RoutineCall,ReturnC,b]
[Note, [Var,b]] // b now has a copy of c
You sir, are a gentleman and a scholar!
