Is there any easy quick way to Scale Offset Copy/Paste between two different subtools? I can not even copy the values with ctrl+c, it doesn’t work, and typing is a pain with a stylus.
Then I need to type manually a lot of numbers and each time that I click a number with the stylus the slider goes nut and changes randomly the number. It only supports mouse really.
There was a cool plugin for doing this from Marcus Civis, but it doesn’t seem to be working in the current version of Zbrush.
I’ve updated it again…
