RUN OUT OF UNDO'S? here's a cool trick
Hi I don’t know if I’m the only one to notice this or if its common knowledge, if it’s the latter I apologise if I sound like im stating the obvious.
Any way last night I was working on a project and made a few mistakes, unfortunately I did not have enough undo’s left not wanting to restart form my last save point I looked around for a way to take it back to it’s original sate.
:bulb: Then it hit me the Z script was set to record automatically when ever ZBrush was started so I saved it out. Played it up to the point just before I made the mistakes and what do ya know there was my model back to its previous state.
Ways to use it:
Just make sure your Z scripts are set to auto record
Try to start ZBrush from a fresh state when working for best results (I.e. initialize it before you begin)
Press escape when the script reaches the point you wish to start reediting you model.
Hope this helps :wink:
Good idea actually. Thanks.
Yup, I didn’t think of that. That will help alot! Thank you Mr smarty-pants :smiley:
brilliant thought! will help in case of Xtreme need :+1:
I found a neat trick that helps the limited undos as well…getting better at Zbrush :smiley:
