Request: perspective warning for projection master
Once again, I’ve just screwed up a texture on wich I spend long time on, just because perspective was enabled and it’s not compatible with projection master:angry:
Would it be posible fore someone to make a warning pannel, when you launch projection master with prespective enabled?
Hello Seb,
Unzip this to your ZStartup\ZPlugs folder. There are two files, PM_PerspTest.zsc and pmPerspTest-button.psd. Both should be in the ZPlugs folder. Restart ZBrush and you will find a new button called Projection Master(p) in the ZPlugin:Projection Master palette.
The best way to work is to assign the hotkey ‘G’ to the button. You can also use the new button to replace the PM one on your UI if you wish.
How it works:
Pressing the hotkey or button will first check to see if Perspective is on. If it is off the PM dialog will appear. If it is ON then a new dialog will appear giving you the option to Switch OFF Perspective, leave it ON or Cancel. Choosing Switch OFF will switch off Perspective before launching PM. Pressing the spacebar will also choose this option.
It works perfectly:+1:
Thank you very much Marcus, it will be extremely helpfull…:+1: :+1: :+1:
hi!
just a question, no request… regarding perspective-mode issues.
i just had a topology problem with a mesh in perspective-mode. trying to retopologize and the points where a little of the basemesh. after turning off perpective-mode everything was fine…
so, just me and my mesh or another candidate for a plugin…?
chem!
ps: right now, i`m re-reading the topology and flow lab thread… maybe this problem is already solved …
this reply is a test, i cant get the dang forum to let me make threads or replys, idk why, it says it does but i cant find any of them.
Thank you so much for this script works great.
Thank you so much for this script!
I messed around in PM for quite some time, and screwed it up by using perspective.
Thanks for all your other wonderful scripts as well :slight_smile:
Best
Henning
