Question: visible subtools?
Hello guys,
I’m just starting zscript, and I have a question. I would like to operate an action only on visible subtools. Is there any commands to do that ?
I was thinking to make a condition
[loop,
[If, [xxxx]//if the subtool is visible
[ISet,Tool:Geometry:SDiv,4]
, [IPress,Tool:SubTool:SelectDown] //and check the second one
I just miss the ‘xxxx’ part :frowning:
Thank you in advance for your help !
You can use [IModGet] to test if a subtool is visible or not:
[IButton,“Test All”,“Test SubTool Visibility”,
[VarSet,activST,[SubToolGetActiveIndex]]
[Loop,[SubToolGetCount],
[SubToolSelect,[Val,n]]
[VarSet,STname,[IGetTitle,Tool:ItemInfo]]
[VarSet,STname,[StrExtract,STname,0,[StrLength,STname]-2]]
[If,[IModGet,[StrMerge,“Tool:Sub Tool:”,STname]]>=16,
[Note,[StrMerge,“SubTool #”,[Val,n]," is VISIBLE"],1]
[Note,[StrMerge,“SubTool #”,[Val,n]," is HIDDEN"],1]
,n]
[SubToolSelect,activST]
