Hello,
I was aware of that ZBrush supports UDIM exports but is there any way i can import multiple textures with UDIM?
Or does it have to be manual like this post explains?
Thank you,
Aiden
Hello,
Thank you,
Aiden
ZBrush can’t display multiple textures on a single mesh. If you want to display the textures you need to split the mesh into separate subtools (based on the UVs) or convert to polypaint as in the tutorial.
