Hi Marcus
Thank you very much for your reply, I have solved the problem of the shadow.
About lightcap,
My idea is to load the default panorama, then automatically switch to the image, then use it to generate HDRI lighting, it doesn’t seem to need this step, because I have been pre-generated Lightcap, I only need to load them…
Now I need to load Lightcap and panorama, it can automatically switch to this image, but at the moment I can only load but can not switch the image, the panorama is always my choice of the first.
About light,
According to your script, I can load light preset, which is to replace the current set of lights, but I hope that lights on / off, because I close other lights, only to open a light, I will only adjust the light effect, then open the other lights.
can I use the script to open the Lightbox panel and switch to the “ZLightCaps” folder so that I can see directly the effect I want to load.
PS:After the completion of these tools, I can make a case teaching video to show the ZBrush rendering and post process, hoping to help more people to use.
Although ZBrush rendering has some shortcomings, but most of the time, only I need to render a lot of reflection or transparent objects, I will use the keyshot, because the only time to keyshot show a strong advantage than ZBrush, otherwise either the rendering speed or accuracy, or set the material and environment of the time, it will be slower than zbrush.
Finally, thank you again for your help!!
