Question:How to create a float colorselector with Zscript?
Hi all,
Does anyone know if it is possible to create a float colorselector with Zscript?
(Just like the slider which pop up when i press “spacebar” .I know pressing down ctrl and draging, but I don’t want that.)And if so how?
I tried to use [note] and [isilder] (The Isilder is also not enough big :stuck_out_tongue: ),
and I also have no way to draw a new color plank with Zscript.
Could give me some suggestions?
thanks !
The hotkey ‘C’ will pick the color under the cursor. If you want to create swatches of colors for saving and reloading later try my ZSwatch zscript (see my signature).
Thanks marcus_civis:laughing:
I know to use “C” key.
But I hope to hide all interface elements until I use one of them,Only one tool that shows I hope to see(not press “TAB” key) .
Do you know how to add the colorselector to quickmenu?
Or there are other methods?
Hi gxhandy,
As far as I know, there’s no way of adding color (or anything else) to the quick menu.
Yes! I give up!:cry:
I switch many interface documents to attain the purpose that I want now!
Use also quite good!
Thanks for your help very much!:laughing:
