This should be easy, but it’s eluding me, my Zfu must be weak today
How do you get the current zbrush project file name? As shown the titlebar (after the hardware ID) + .ZPR
[VarSet, ZbrushFileName, ???]
AFAIK, you can’t. You can get name of loaded file(last used) or last typed.
Doug is right, there’s no way to get the current project name unless you manage to grab it using [FileNameGetLastUsed] or similar.
Cheers fellas.
Would it worth adding as a suggestion to future versions of ZBrush? If so, where can I make that suggestion?
You can submit a support ticket as a “Feature Request”. That’s probably the best way.
