Note that use of this plugin is at your own risk. Be sure to back up your work before using!
Installation
If you installed the previous version make sure you delete both the PoserUtilities01.ZSC file and PoserUtilitiesData folder from your ZBrush 4R7\ZStartup\ZPlugs folder before installing the new version.
- Unzip the zip file to your Desktop making sure that the unzipping program preserves the file/folder structure. Generally a folder called ‘PoserUtilities_4R7’ will be created. Inside this will be the actual plugin files/folder.
- You should have a PoserUtilities_4R7.ZSC file and a PoserUtilitiesData folder (which contains three files). Copy the PoserUtilities_4R7.ZSC file and PoserUtilitiesData folder to your ZBrush 4R7<b>ZStartup\ZPlugs64 folder. This installs the plugin for ZBrush 64bit.
- Also copy the PoserUtilities_4R7.ZSC file and PoserUtilitiesData folder to your ZBrush 4R7<b>ZStartup\ZPlugs folder. This installs the plugin for ZBrush 32bit.
- Restart ZBrush. You will find a new submenu called ‘Poser Utilities’ in the Zplugin palette.
Instructions
*Export Groups to OBJs
Press the ‘Export Groups to OBJs’ button to export an OBJ for each group of the current mesh.
This button will export the selected mesh in ZBrush as separate OBJ files for each polygroup. The filenames will be the names of the groups in ZBrush. If the polygroups were assigned in ZBrush then these names will be something like ‘Group43598’. If an OBJ was imported into ZBrush then the group names are preserved so long as no new polygroups where created inside ZBrush. That ‘Save As’ dialogue is just for selecting a folder for the files; the entered file name will not be used.
*SubTools to Groups
Press ‘SubTools to Groups’ button to export the visible SubTools as separate groups to a single OBJ file. The SubTool name will be the name of the group and duplicate names will have ‘_copy’ added. Currently UVs are NOT exported. Note that the selected subdivision level for each SubTool will be used so make sure to set all to the level you want before exporting.
*Export OBJ
Press the ‘Export OBJ’ button to export an OBJ so that unused points are restored. ZBrush will remove unused points when importing an OBJ; this option will restore them (as well as any groups and group names that are in the original file). When you press the button you will first be asked to choose a file name to save the new OBJ, then you will be asked to select the original OBJ that you exported from Poser. (Note that if you select this file as the ‘Save As’ file the plugin will still work but your original file will be overwritten.)
*Export Restore Groups
This will restore original groups and group names from the original OBJ. This is useful because ZBrush doesn’t keep the group names. It also means that you can change the polygroups while working in ZBrush. When you press the button you will first be asked to choose a file name to save the new OBJ, then you will be asked to select the original OBJ that you exported from Poser.
This new 4R7 version should work with both Windows and Mac OSX.
Download here for 4R7 :
PoserUtilities_4R7.zip (316.7 KB)
I hope you find this useful. Please post any questions/suggestions in this thread.
