Please solve the problem of the decimation master (There are no cases at all.)
022 011
When performing “decimate current” using the decimation master, a bug occurs in which all sub-tools are flipped upside-down, and the outside and inside are reversed.
cannot specify which subtool is causing the problem (the subtool that causes the problem will be different each time you try) and undoing will not restore it to its original state.
It did not occur at all in the pre-process phase, and this error occurs randomly when only “decimate current” is pressed.
Checking all the options of the decimation master (freeze border, keep uvs, etc) was of no use at all. Even reinstalling, the same problem occurs.
Before importing in 3ds max, I have sorted the axes and reset the xform, everything I could do, but to no avail.
It is useless to append a new subtool using make poly mesh 3d in zbrush.
It is so large that it is impossible to save, load and work at every moment.
I tried to find a solution on google, but couldn’t find a case.
Here are the computer specifications.
OS Windows10 64bit
32 gb ram
CPU AMD Ryzen 5 1600 6core 3.2ghz
GPU gtx 1060 6gb
I’ve tried every method I can try, but I can’t find a solution.
115
It is a “decimate current”, not a “decimate all”, and subtool are individual subtool not merged.
224
If a bug occurs during the operation, all imported files (saved files without bugs) are loaded upside down (recovered by restarting zbrush).
Answered in other forum:
