i got a script that works fine when loadet in zbrush.
when i wanna record the movie with zbrush, the recording stops short after running.
the point of recording is there but it doesnot record.
can someone record it for me and send me the film back?
I need it for another forum to share with my friends and i wanna post it here too!
Please check out whats the problem…
This zscript was recorded with ZBrush 3.0 and won’t play correctly with ZBrush 3.1. It also loads a model from your hard drive. Obviously anybody playing back the script would need that model in the same location, so you won’t get much luck with your request. Also, with problem zscripts it is a good idea to post the text file rather than the .zsc, so that edits can be made if necessary.
I’ve not tested the movie recording while playing zscripts, so I don’t know if there are any restrictions. If you’re in a hurry you might try the trial version of
Camtasia or there is the free Camstudio .
