Hello. Whether I can write [Note, Message, in the other language, for example Russian? Excuse for my bad English. Thanks.
Hi Yurak,
If you are more comfortable with Russian, I believe their is a Russian Zbrush forum either pixologic or someone else started. I donāt have a link to it handy but perhaps someone else will and post it here.
In the meantimeā¦a āgoogleā search on the internet would probably be a good place to start.
Also if you posted in Russian, itās possible one of our fellow zbrushers who also speaks Russian may stop by to help you if you have a question.
If you are just posting up some workā¦Art has a universal language so please feel free to post your work!!
YuracK
You can post in Russian and viewers can use babble fish to translate
OR
You can use babble fish and translate into English and copy and paste into a post
BTW Like your art work
SpaceMan
Ahhh yesā¦i knew your nickname was familiarā¦I like what you have posted so farā¦good stuffā¦shows lots of promise and talentā¦
do not be shy and post your works and wips in the main forum!!!
And as Spaceman saidā¦almost any language can be translated via online translator nowadaysā¦so post in your language of comfortā¦but definitely post!!
Hi Yurak,
If you meant can you write a [Note] in Russian, I think probably not. But there is a workaround. Make an image with the text you want and then write this code (12 commas between āNoteā and the image):
[Note,,,,,,,,,,,,image.psd]
<span class="grey">Make sure the image is in the same folder as your zscript.
Excuse the Russian - online translation!
hahaha dohhh
Marcus you are probably on the moneyā¦I donāt know why it
didnāt occur to me he meant with zscriptsā¦
ok as I told Svenā¦Am gonna have to change my nick to either amiadork or howdensecanibe!
duh
marcus_civis I think is on the right track with his post
duh zscripting forum for zscripting info
YuraK
Ok spacemanā¦I deserved that one!
but i rarely pay attention to where i am at in life let alone at zbc so amilost would probably be more fitting.
LOL aminuts I was making the comments about my post - as I didnāt notice that I was at the zscripting fourm at the time I posted here - itās a LOL at myself.
