Mesh size in subtool
Hello, when I duplicate a small sphere in the subtool (duplicate) I have 2directions (X,Y for example) that allow me to move the subtool, but on the 3rd direction, there is extrude in the place of displacement. I don’t see where the setting error is? Thanks for your advice!!
2022-03-21_08-05-48
Hello @fl0645 ,
I’m going to guess that you have Symmetry active? If so, you may need to deactivate that for this operation. When Symmetry is active and the spheres of influence of the Gizmo overlap near the center line, conflicts like this are possible. In those cases you must deactivate symmetry, perform the operation on one side, then manually mirror those changes to the other side if necessary.
It’s also possible that this is an issue with where you have placed the center of influence of the Gizmo manipulator. If you’d like to center it someplace else, unlock the manipulator and reposition it either manually, or with the “Go to Unmasked Center” option.
:slightly_smiling_face:
