Indiana Jones and The Great Circle - Necropolis Environment Sculpts
Hey everyone!
Been a long time since I posted here but while I was taking screenshots with some of the work I have done for Indiana Jones and The Great Circle, I figured I would share some of the sculpts I have done on Zbrush Central as well :slight_smile:
The sculpts bellow were mainly created in the context of the Warrior’s Tomb Mausoleum area, within a Necropolis found under Vatican that the player gets to explore as a full level during the first part of the game.
While being built by and for crusaders, the architecture in this room was meant to be highly reminiscent of the Roman Architecture, which is what I based most sculpts on as primary reference.
Most of these models were first blocked out in Modo, then exported and sculpted in Zbrush.
Ingame screenshots can be seen here
https://www.artstation.com/artwork/Ov0aRv
More from the work I have done for the game
https://www.artstation.com/danmihaila
necropolis_hps_dmihaila_shot00a
necropolis_hps_dmihaila_shot03a necropolis_hps_dmihaila_shot04b necropolis_hps_dmihaila_shot06a necropolis_hps_dmihaila_shot06b necropolis_hps_dmihaila_shot07a necropolis_hps_dmihaila_shot07c necropolis_hps_dmihaila_shot09b necropolis_hps_dmihaila_shot10a necropolis_hps_dmihaila_shot10b necropolis_hps_dmihaila_shot12a necropolis_hps_dmihaila_shot14a necropolis_hps_dmihaila_shot14b necropolis_hps_dmihaila_shot15b necropolis_hps_dmihaila_shot16a necropolis_hps_dmihaila_shot16c necropolis_hps_dmihaila_shot17a necropolis_hps_dmihaila_shot17b necropolis_hps_dmihaila_shot17c
What an absolute joy to see this level of environment art here on ZBC. Love those trims man. Thank you so much for posting! Staff pick nominated :slight_smile:
:mechanical_arm: :trophy:
That is awesome to hear, thank you for the kind words! :slight_smile:
Here are a few more renders containing a mix of unique sculpts of midpoly assets as well as assets done from scratch via traditional means and finally, assets that are mainly scanned objects which were then further tweaked/fixed/adjusted in ZBrush.
I will provide a bit more info bellow within each batch of assets:
Midpoly assets. These meshes ended up being decimated and then textured via tiles + material blends in the engine
necropolis_hps_dmihaila_shot01a necropolis_hps_dmihaila_shot01b necropolis_hps_dmihaila_shot02a
Assets done from scratch (blockouts in Modo, then sculpted in Zbrush):
necropolis_hps_dmihaila_shot13b necropolis_hps_dmihaila_shot08a necropolis_hps_dmihaila_shot12b3
Assets that are scans which were then modified in Zbrush
The biggest modifications can be seen for example on the Oceanus and sons busts, which started from some scaned busts, which were then combined with scanned coral assets and then on top of that I did some manual sculpting to integrate the two main elements together.
Other modifications included changes in size, addition of cloth elements which were simulated in Marvelous then finished in Zbrush, adding destruction on some or simple changes of general measurements/proportions.
necropolis_hps_dmihaila_shot05a
necropolis_hps_dmihaila_shot11a necropolis_hps_dmihaila_shot11b necropolis_hps_dmihaila_shot11c necropolis_hps_dmihaila_shot11e necropolis_hps_dmihaila_shot18a necropolis_hps_dmihaila_shot20a necropolis_hps_dmihaila_shot22a necropolis_hps_dmihaila_shot22b necropolis_hps_dmihaila_shot22c
