Import SVG issue
Please help me to find the reason for the wrong SVG-file import:
ZBrush Document
SVG viewer shows it properly:
Thanks in advance
Hello @yesbird65 ,
Does the file contain only closed paths with no open curves? Is it completely flattened? Layers aren’t supported. Shapes must not overlap.
These would be the most common reasons a svg file wont return the expected results. If you don’t think this describes your problem then you would need to contact ZBrush support for us to take a closer look at your file.
Thank you!
