1.-I want to put the Play button aligned, but when i have three o more they become down.
2.-The PenMove have values -10,-30 or 90 etc, what are the parameter to choose that values.
3.Where i can see that numbers?
Thanks in advance
Andreseloy
Here is the definition of the PenMove command
[PenMove,Horizontal Offset,Vertical Offset]
[color=Orange]Moves the pen a relative distance
think of the pen as resting where it last was moved to. This command will move it in the X and Y directions according to your input.
Positive Horizontal - Moves pen to right
Negative </span>Horizontal [color=Black] - Moves pen to Left
Postive Vertical - Moves Pen Down
Negative Vertical - Moves Pen Up
Example:
If you put a button down at coordinates of 0,0 and the button is 32 pixols wide and 16 pixols in height the pen will be resting at X = 32, Y=0
To place a second button directly below that one you would create a Penmove
[PenMove,-32,16]
This brings the Pen to X=0 Y=16
This is where your next button or graphic will be placed.
Hope this helps
I wll try and post what i want and what i get¡
Very kind from you as always
Andreseloy
Hi Mario,
The [PenMove,…] command has no effect on buttons/sliders/switches of Zplugins. It only works with buttons/sliders/switches of regular Zscripts that are displayed in the Zscript Window.
Thanks Mark
Andreseloy
