Very cool, thanks
really great tut man!!!
my workflow is maya-zbrush-maya without using xnormal first modeling the lowpoly in maya, unwrapping it in maya and then going to zbrush to detail it. The thing is that generally in in zbrush i see the texturing and the other maps perfectly, but when i go to maya, at the seams there’s a huge gap between the seams, does it has anything to do with the smooth UV’s in zbrush? what can i do?
thanks again great tut.
www.david_guardado.cgarena.com
http://vimeo.com/5095322
www.allbgear.com
Helpful thanks for the post
I have been looking for something like this for a long time, I should have known to check zbrush central!
T H A N K Y O U
Gah so much info so fast! It’d be great if this was slightly better video quality because it’s hard to see what you’re doing in photoshop and Xnormal. But it seems you’re overlaying the normal map made from diffuse (but delete green channel) over other normal map made from high poly model in Xnormal to make it look grittier and also
- color map + ambient occlusion map on top with multiply + texture found online overlayed = diffuse map? Sorry for the weird text format, I was taking notes and copied-pasted from there.
Very insightful. And funny.
HD Video for this tutorial is available on Vimeo.
Nice video! Thanks for sharing.
Hi guys!
I have great tutorial which covers the whole approach of high to low poly for games alike.
Check it out here:
[youtubehd]dMcVD6Ir0aA[/youtubehd]
Hope you like it and if you have any problems with the process just let me know.
Kieren.
