Hard edge displacement map baking issue
Hi, I have a bit of a problem baking displacement map with Zbrush.
I sculpt some object with sharp edges. weapons. bucklets ecc.
This how they look in Zbrush
Screenshot 2024-07-17 230917
But the problems arise when I try to bake the displacement map because some darkedges appears in the map itself
Screenshot 2024-07-17 232011
With those risults…
Screenshot 2024-07-17 232456
This is appen with all other object with hard edges, I tried various set up but everyone with the same result. Somebody can point what I am missing?
Thanks and sorry for my broken english
Ok, while I was writing my post I found the solution… :eyes:
Apparently if you leave your “crease edge” activate they will appears in displacement map. I “uncrease” all the object and no more dark edges.
I leave this post here in case someone stuck in the same problem
