I’ve done it and nothing. I keep getting the export button but not the import.
Screen Shot 2022-03-18 at 1.39.53 AM
I even uninstall the program and re install it again blender 2.83, 2.93 and 3.1 versions and that didn’t work, the only version that actually showed the export button was the 2.83 version.
Thank you so much for your help.
And now i have new error in z Brush and error in blender ( i run with Administrator)ZBrush_MLbqKX72yK blender_122Thb43NQ blender_BnQagX5ZLg
@Siamir_Yosam_Cardena I think that your interface is covering it. Delete a tab or two and see if it is there now.
@111868 :
Actually, I somehow got it to work.
I removed the plugin. Imported it again, not sure if that mattered at all.
Next I used the “Install Goz” button in the plugin troubleshooting area in blender. Make sure zbrush is closed first. Then install goz that way.
Open up zbrush, preferences, goz and then click on the path to blender button.
Select the blender exe in the program files location.
make sure you have an object open already in zbrush. In blender click on the import button so it highlights.
after that is there, open the tool pallet in zbrush and click on goz. It should transfer.
I tried the base head model to see and it worked without issue this time. I followed the repositories instructions and that did not work for me. However, I was able to send from blender to zbrush. Just not the other way around.
version 3_5_86 has been released, thanks for all the bug reports and feature requests.
main changes and fixes have been done in 3_5_85 and are all included in 3_5_86
A new release is available, the main feature is the support of the long awaited Face sets feature thanks to a contribution of user [00004707]
This release also comes with new icons and contains a lot of bug fixes.
The addon is also awaiting approval on the extensions platform and you should already be able to get it from there if you run blender 4.2+
