Ganesha Ashok Binayak
Concept and Element Design
From the meaning of wind I often think of clouds with a breeze blowing through them. Until it becomes various shapes and symbols That conveys the meaning of nature and the wind that I insert into my work.
40x50 poster3 copy
g01
Ashok.7181
Ashok.7178 copy
Ashok.7179 copy
Ashok.7180 copy
Various angles
Ashok.7212
Ashok.7213 copy
Ashok.7216
Ashok.7215 Ashok.7208 Ashok.7214 Ashok.7205 Ashok.7206 Ashok.7207
This is excellence!!
Thank you. :smiling_face_with_three_hearts:
Concept and Symbol of Ganesha Ashok Binayak.
องค์ประกอบ copy eng
Designing for me starts with solving problems. For example, the Thai pattern on the back of the starting point is a result of solving the problem of “weight bearing” because this will be the first work that is larger than 15 inches. The fabric that supports the weight in one place, I think, will have a problem. Therefore, the scene was designed for this purpose. and add symbols Nature and “infinity” conceal auspiciousness to the work.
Ashok.7114
After considering for a while and print out the work to see So I decided Modify the facial structure slightly to make it more expressive.
0017
gradually developed Until it’s perfect
raykan03.6935 raykan03.6936 raykan03.6943 raykan03.6955 raykan03.6988 raykan03.7024 Ashok.7169
Ashok.7172 Ashok.7170
Beautiful sculpt!
Thank you.
Coin type, size 4.2 cm.
Ashokraygan.7233 copy
Amazing work man!
Thank you.
4.7cm450121127_800932638843088_6493879619198098746_n
The work is currently being created in a 23-inch size, cast in bronze.
504240647_692300160391522_5505658448067816252_n
Exhibited at the “It’s Art” exhibition at The Paseo Park, Kanchanaphisek, Thailand.
pro
