FBX import dialog window cut off
I’m having an issue where the import window is cut off and the import button isn’t visible. I can’t even exit the menu because of this because the cancel button also wont render.
I have 3 monitors in my setup, a 1920x1080 monitor, a 1920x1080 display tablet, and a 4k monitor. I’m using the display tablet for zbrush, but I think it might be the 4k monitor causing the issue, even though its not being used.
I really need a fix for this. Screenshot 2023-06-15 134141
Hello @Ottomottoo ,
Please contact Support for any technical issues with ZBrush. We can’t provide technical support over the public forums and other users probably wont be able to help you with system specific problems.
Thank you!
