EaZy Toolz
This plugin contains some buttons to do some simple things to save time. The features it contains now are:
-Extracting a mask without out thicknes and without the ugly rough edge.
-Making a duplicate of current subtool and makes it ready for an insert brush to be used after that you hide hit a button to delete everything except for the inserted meshes.
-Does a quick 4x4 of Sdivs and makes the outcome the number of loops of panel loops this allows you to reconstruct after panel loops.
-Bake all layers on all subtools.
-My favorite A switch to turn off and on all surface noise on all subtools.
-Just hitting export for all subtools you can quickly name them from 1 to whatever number you end with.(Great when sculpting a lot of assets and having them decimated in same order in a differ Ztool)
-switching sub group export on and off on ll subtools.
-Dynamesh with a custom amount of polish (Someone told me dynamesh with polish didn’t work correctly so this is why it’s in here).
-A slider to set the sdviv for all subtools at once(I know there is a high/low vis all but I think this works a little bit nicer).
-New auto groups this works much faster on heavy subtools when the polycount is way up there and you don’t have sdiv(Tested it with some simple divided cylinders with a pretty high polycount without sdiv. It saved me 1 minute and 37 seconds)
I’m still planning on adding more to the plugin once I find some more annoying things that I hate doing. If you have any ideas for features feel free to tell me. Also if something doesn’t work please let me know so I can fix it.
Link: https://gumroad.com/l/eUxqE
The plugin is free.
To Install just paste the zsc file in your zbrush plugin folder.
Huge thanks to marcus_civis for always helping out with problems.
Video of the features.
[video] https://www.youtube.com/watch?v=aK0fTuQ5178[/video]
Good Job
Nice work! :o
The video link doesn’t seem to work. But doing a search it seems to be here
I hope this is correct
