Hi
The DPI ZScript is a utility ZScript which you may find helpful when calculating the print-size of a ZBrush document or when creating a new document which is intended to be printed in a specified size and resolution (such 5x8 inches at 300 Dots Per Inch ).
Click here to download the DPI ZScript
Installation instructions…
- Extract the downloaded zip file and put the extracted dpi.zsc file within your ZScript folder.
- Launch ZBrush and load the ZScript.
Print-size preview:
This script also allows you to preview the actual print-size of a document. The ZScript contains a calibration slider which allows for accurate print-size-preview regardless of the size of monitor and resolution used.
In order to calibrate this slider you simply use a ruler and measure the length of the slider on your monitor. When this value is entered, the ZScript will accurately adjust the print-size-preview to fit your monitor size and resolution. Furthermore, the DPI ZScript will ‘remember’ the result of the calibration and will automatically use it in subsequent ZBrush sessions.
Hope you’ll find this ZScript useful
-Pixolator
Note: This is a preliminary version of the DPI ZScript, the final version will be included with the next ZBrush release (v1.6)</font>
