Damaged Brick Wall Tutorial - VOL 11
The subject of this training is bricks, the most widely used and diverse material in the real world and the world of computer graphics. After seeing this tutorial, we will have a good understanding of making a brick material, and by changing the initial parameters, you can get the result you want.
So let’s see how to make a Brick wall in three different alternatives in the Substance Designer!
More Info:
https://www.artstation.com/a/16605165
Contents:
- 155 minutes of unnarrated videos
- 1080 Resolution
Chapters:
Chapter 01
In this chapter, we create Bricks’ basic structure and add surface details and additive details to them like edge damages and Cracks. We will use different maps and blend them to achieve the desired result.
Chapter 02
The next step is creating the color and roughness data for this material. For this tutorial, we use the gradient map to make our color data with a few colors and blend them with different grunge maps to get what we want. And for roughness data, we are using a simple and effective way for this type of material.
Chapter 03
Finally, after making the original material, we move on to making different alternatives. We will build a brick wall with fallen bricks and a brick wall with Plaster Cover.
Software Used:
Substance Designer
Level:
Intermediate
Prerequisite Basic knowledge of Substance Designer
Attention: clean SBS file is included in this product that you can study over that (version of the designer should be 11.3 or above)
Attention: all videos are unnarrated (it means there are no voice-over videos or subtitles)
Do you want it ?
Chesterfield Leather Tutorial - VOL 10 :
https://www.artstation.com/a/16359215
Scifi Padded Wall Tutorial - VOL 09 :
https://www.artstation.com/a/16161943
Metal Railway Tutorial - VOL 08 :
https://www.artstation.com/a/16017894
Broken Roof Tiles Tutorial - VOL 07:
https://www.artstation.com/a/15815559
Metal Retaining Wall Tutorial - VOL 06 :
https://www.artstation.com/a/15570800
STYLIZED PAVEMENT WITH MOSS Tutorial - VOL 05 :
https://www.artstation.com/a/15406536
Stylized Plaster Wall Tutorial - VOL 04:
https://www.artstation.com/a/15331498
Handmade Mosaic Tutorial - VOL 03:
https://www.artstation.com/a/15064540
Damaged Concrete Tutorial VOL-02:
https://www.artstation.com/a/14950781
Broken Tiles Tutorial - VOL 01:
https://www.artstation.com/a/14922290
Facade In Substance Designer Tutorial:
https://www.artstation.com/a/5308958
