“” and “/”
what is the correct syntax for custom paths? i want them directly on the “D” HDD.
It would be [color=#FE7C01] D:\ [/color] if you want it on the root or [color=#FE7C01] D:\FolderName\ [/color] if you create a folder. Remove the “C:\Users\Public\Documents/ZBrushData2020/” that you’re showing in your image though. The following image is how I have mine.
It would be the same for the Quick Save Path.
