CPU at 100% with 2 million Polys?
I have a new PC which is pretty good spec, AMD Ryzen 5 3600 Hex core processor.
RTX 370 TI
32GB Ram.
And when navigating in zbrush, moving the viewport, it uses 100% processor. This is the same for any Ztool. I have windows 11 updated to the most recent and Zbrush 2022 updated with the latest patch.
ZBrush Processor1
Would really love some help from anyone so i can get working again!
Hello @EddieV ,
This is not out of the ordinary. ZBrush is a demanding application that will greedily use all the system resources it can get its hands on if it thinks it can use them. You can max out CPU usage doing nothing more than navigating with a fairly low resolution model if you continuously move the model around the viewport at length. This is especially true of meshes at a single level of resolution with no lower level of subdivision for ZBrush to substitute during the navigation process.
Remember that ZBrush is CPU-based, and does not offload any performance burden to the GPU in most situations. Your CPU will be doing all the work redrawing the canvas as you update it.
If you think you’re experiencing an issue that is not explained by the above, please contact ZBrush Support. Technical support for ZBrush cannot be provided over the community forums.
Thank you!
