BUG: Project_color button Fail on Custom UI
Hi, i was making my custom UI, i put the ProjectAll, Geometry and Color buttons and exactly after i project only with the Color button turn on the button transform into the first subtool of my file. Well, I also take this opportunity to say that the zremesher button does not work with the alt pressed if it is in a custom ui (old one bug)
im using zb 2022.0.5
i didnt find any fixes on latest versions :
[Update to ZBrush 2022.0.8 - ZBrushCentral(ZBrush 2022.0.8 - Download Now! - ZBrushCentral)
Update to ZBrush 2023.2 - ZBrushCentral
Hello @blindnees ,
I can’t immediately reproduce what you report from the description. Please contact Maxon support for any suspected bugs or technical issues with the program.
In the case of custom UI, please ensure the UI was created in the version of the program you are using, and not ported forward from an earlier version. While you can often continue to use a UI in newer versions, things do change in between releases and any UI functions that reference features that have changed may not work correctly. If a custom UI related function ever fails to work as expected and it was created in an earlier version of the program, this is the first thing you should do.
Thank you!
