Booleans Ops? Concatenating a number with a string?
Here’s a routine I’m writing to find the currently active layer, based on TVEyes’ older article:
[RoutineDef, GetActiveLayer,
[Loop, 16,
[VarSet, layer, [StrMerge, "Layer:Layer ", n+1]]
[VarSet, flags, [IGetFlags, layer]]
[If, (flags=10) || (flags=11),
[VarSet, result, layer]
[LoopExit]
, n]
, result]
I haven’t yet tried to run it; for one thing, I need to know the boolean or operator in ZScript (line 5), and can’t find it in the reference materials.
And while I’m asking questions, does anyone know if line 3 (concatenating a number to the end of a string with StrMerge) will work? If not, how should this be done.
Thanks,
Ken
Use double == signs for comparison.
if you are asking If Flags is equal to 10 or 11
[If, (flags==10) || (flags==11),…
The stringMerge should work like this. [Var,n]+1
[VarSet, layer, [StrMerge, "Layer:Layer ", [Var,n]+1]]
just having n+1 as an argument may crash ZBrush or give you the string “n+1”
Actually, the loop counter variable doesn’t return the right value when you try to add to it in a StrMerge. It’s fine left on its own but then you’ll have a value of 0 to contend with and there’s no Layer 0.
The simplest way is to do this:
[Loop, 16,
[VarSet,x,(n+1)]
[VarSet, layer, [StrMerge, "Layer:layer ",x]]
On signs, I think in If statements, (although either work fine as above) single is more dependable:
[IButton,,,
	[VarDef,p,27]
	[VarDef,y,25]
	[If,p|y>24,
		[Note,OK],[Note,NOT]
[IButton,,,
	[VarDef,p,27]
	[VarDef,y,25]
	[If,p||y>24,
I use the [Val,…] command to include the loop counter in the [StrMerge,…].
 [VarSet, LayerActive, 0]
 [VarSet, LayerCount, 0]
 [Ibutton, "Layers Info",,
 [Loop, 16,
 [If, [IGetFlags, [StrMerge, "Layer:Layer ", [Val, n+1]]] > 9,//there can only be 1 layer with flag 10 or 11
 	[VarSet, LayerActive, n+1]
 [If, [IGetFlags, [StrMerge, "Layer:Layer ", [Val, n+1]]] = 0,//layer is not created
 	[VarSet, LayerCount, n]
 	[LoopExit]// no need to test more layers
 ,n]
 [Note, [StrMerge, "Active Layer :   ", LayerActive, "
Number of Layers : ", LayerCount]]
   Depending on what you want to do you might also have to test for created layers that are disabled/hidden (flag 8).
You can also use the Interface Item ID numbers for Layer buttons:
[VarSet, LayerID, 3841 + counter ] // where counter would be 1 thru 16
