Hey guys, I thought you might find this useful… using BPR material blending to do a bit of ‘compositing’ directly inside ZBrush:
I walk you through this quick set up on my latest ZbrushLive streaming session (episode 12) in case you want to check it out.
Also, here is a sketch I started on the stream (I did work more on it after the stream but ill show you the technique i used during next week’s session):
