Background (Light->Backgound) Images does not apear in the canvas!
Hi Community!
I was following this Tutorial from Michael Pavlovich - https://www.youtube.com/watch?v=pTgjNve4QlI - “Zbrush Image Based Lightning: 007 Background Image” and I can’t figure out, why with the simplest settings, the HDR Image (Zbrush 2-Pulchri = provided by Zbrush) is not being shown in the canvas.
Just after the BPR render process is done, the image appears. But this gives me a hard time to adjust the image (Longitude, Latitude, Tilt, etc).
The Problem / Situation persist regardless the Type of image that is being used.
I can import an image with the Texture->Image Plane-> Load Image tool. But it’s just a workaround solution and would rather apply this tool as easily as the Pixologic Tutorial → ZBrush - The World's Leading Digital Sculpting Solution describes.
I have restarted Zbrush a couple of times and followed the Background Image - User Guide (the image does not apear in the canvas)
What im missing here?
Update! one thing that I notice, is when the hole PC / Laptop is turned off (a complete restart) and then Zbrush is started, then the Background image (Light-> Background) works perfectly fine, as its suppose to do.
This has currently work while Using a default tool (one of the bunch that Zbrush provides as a default ) and not having loaded any Tool or File.
But as soon as a open, a stored file… (at the moment I tried a .ZPR type of file), the issue comes back. And it stays, regardless how many times Zbrush is restarted.
I will keep trying / keep you posted.
