BA-Thesis ZScript//////// Creating Masks for dDo, Quixel Suite and Compositing
Latest Update:
Hey there,
i’m currently studying 3D Art & Animation and i’m doing my BA-Thesis about optimizing the Workflow of creating these Masks for dDo and the Quixel Suite.
Since my Research Method is Action Research, I created a first Version of my final Plugin.
The ZScript assigns a different Color to each Subtool so you can easily bake the High-Poly’s Vertex Colors with xNormal.
This is the link to the script:
https://www.dropbox.com/s/u6918bvp2sv6aoe/Random_Fill_All.zsc
Would be awesome if you could download it, test it and just quickly answer this survey:
Thank you so much in advance!
P.S. To install the Plugin, paste it in C:\Program Files\Pixologic\ZBrush 4R6\ZStartup\ZPlugs and then start ZBrush. Under the ZPlugin Tab you should find “MaskPlug” which contains 1 Button.
Hey there again,
here with some little upgrades… I hope :wink:
Thanks to those who helped me by filling in the form!
New:
#Fixed the Error when a 2.5D Tool was selected
#Added a BPR-Mask-Render Button which colorizes the Subtools randomly, then saves out a Mask for Comp
#Added a Mask-Map Button, which colorizes the Subtools randomly, then, when UV-Mapped, saves out a combined Mask-Map
Would be awesome if you could download the new Version of my Script, test it an fill in the form!
Thanks guys :wink:
https://www.dropbox.com/s/h8j66nvnqwf1qnh/MaskPlug02.zsc
Link to the survey:
P.S. To install the Plugin, paste the MaskPlug02.zsc in C:\Program Files\Pixologic\ZBrush 4R6\ZStartup\ZPlugs and then start ZBrush. Under the ZPlugin Tab you should find “MaskPlug” which contains 1 Button.
Hey again… again :wink:
Soo…
Here’s the final MaskPlug, thanks to those who helped me by filling in the form.
# Fixed a lot of Errors
Added the texture sizes directly
Added an Interface
Hope some of you can use this.
Thanks for your support!
The link to the script:
https://www.dropbox.com/s/z428f45v89hrfv1/MaskPlug.rar
Greets
Tim
Hey there,
if anyone is interested, here ist the new link to the download…
https://www.dropbox.com/s/nk4k9ajn8reox96/MaskPlug.rar?dl=0
Thank you
Thanks a lot, very good idea !!!
One feature you could add which would be wonderful : An option to make only masks pure red, green or blue, so in compositing you could just use the channel as a matte, like in true compositing. (So the plug should proceed making one texture for each series of 3 tools).
I will try it very soon !!!
Great Idea :slight_smile:
Thank you very much :+1:
Very Cool plugin :slight_smile:
All download links are broken. Any chance for a re-upload??
Here’s the new link:
Thanks to all of you for the support!
is it supposed to be working in 4r7 p3?
Thank you very useful and fast
