is there a way to create arrays in zscript, or are you limited to just variables?
also, i am creating a zscript where you can save a file by clicking a button. im using the [filenameask] command, but in the cmd it says that the proper way to write it would be this for loading a file
(replace the bold large a with small arrows)
[FileNameAsk,"DXF (*.dxf)<b>a </b>*.dxf<b>a</b> OBJ (*.obj)<b>a</b> *.obj<b>a</b><b>a</b>,,"Please select a file to load"]
so am i supposed to write the > sign where the arrows are, or do i need to find the hex code for that arrow symbol and type it using alt+numpad?
and my final question, i am working on a plugin where i can save a .zce file (no im not gonna tell you what it stands for) and i was wondering if i can define somewhere what data it saves ( i know how to retrieve the data) and i was also wondering if i had to write a section that tells zbrush how to interpret (sp?) the data in the save file.
wow, this is like, the fifth time im editing this post to add a question.
i was wondering if you could create one of those buttons that turns on and off, like the edit button or the x,y,z mirror buttons.
