An y new Zscript functionalities with Zbrush 4 ?
Hey guys !
I was just wondering if there were new stuff coming out for Zscript compared to the previous versions ?
Thx !
I was hoping so but there’s nothing new in the Commands List, so unless they are not documented I guess no new commands made it in. :frowning:
I would add that…
Since ZScript allows you to ‘click’ any interface items, it automatically get to have more functions with each ZBrush release.
As an example:
If this was not the case, a new ZScript command would have to be written to allow ZScript “Save a project”, but it is not needed because you can use the same IPress command to access this new functionality.
I wasn’t thinking of new functionalities this way : I was expecting new stuff like :
realtime Zscript listener and recorder
write and test you script directly in zbrush
launch multiple scripts at the same
etc…
in few words : some improvement in the overall Zscripting system :slight_smile:
I hope there is documents somewhere that spells out new stuff with version 4, as I just download it. The download was easy, but now the questions arises, why was an upgrade needed?
You can get them here:
:smiley: I jumped the gun as I always do, I found the PDF (three of them) in the software root under documents…thanks…
